iPad: tap gesture will not work anymore if i add also a swipe gesture or an on tap hold gesture to the same button
Thomas Binder shared this problem 6 years ago
If add a swipe gesture or a on tap hold gesture to the same button the tap gesture will not work anymore on my iPad. Since there's no on tap gesture available i'm using the mouse click action at the moment.
It would also be great if there would be an on tap release gesture available.
Comments (6)
It's fixed for the next release. Thanks for telling.
Fixed in version 5.0
Hello Victor,
Sorry to come back to this topic but it is still not working when used on a device for testing.
Working on Mac with OS X 10.7.5.Fine in Safari on the Mac.
When transferred to iPhone 4 or Samsung Note II (Android 4.1.2) then the same issue occurs : "on tap" not triggering if an "on tap hold" event is defined as well. The device will run Chrome or Safari. No difference.
It works for me... could you try this simple example and tell me if it works for you as well? http://d2ld3he4yll0xl.cloudfront.net/... I've done it using 5.5 version.
Hello Victor,
Thanks for the quick feedback.
Your example works very well. The only difference I see is that you did not provide an on Tap but an on Click event.
For some reason (I am preparing a prototype for iPhone 4S maybe) I can't find the On Click event. In fact I have no Mouse based action available in my menu.
What would be the quick work around to get access to the Mouse events until you guys check this out ?
Working with 5.5 as well, still on the 30 days trial.
By the way your product is impressive !
Same prototype but this time with the tap event: http://d2ld3he4yll0xl.cloudfront.net/...
That one also works for me. Could you send your prototype (or a prototype with the error) to jim.support at justinmind.com please?
