invalid configuration location
Samantha shared this problem 7 years ago
I am getting the following error when I try to open JIM
'Invalid Configuration Location - The configuration area at '/Users/samanthag/Justinmind/4.40/configuration' could not be created. - Please choose a writable location using the '- configuration' command line option.'
I am not how to use the command line option ... please help.
I am running Mac OS X Version 10.7.2 ... this includes the latest mac updates.
Comments (20)
Could you describe the installations and updates you made until that error happened? The folder which is referred in the error message is really weird. It should be '/Users/samanthag/Justinmind/4.4.0 instead of '/Users/samanthag/Justinmind/4.40 for some reason a dot has been missed.
We recently installed this in our labs as well and we get this message as well. I think its trying to write something in an admin location and we are using a local account. How can we set to configuration to use a local folder.
Manoj
Did you install the software with an Admin and then launch it with a normal user or did you launch it with the user Admin the first time?
I installed it and launched at as a user, If I remember right I also did the other way.
same exact problem here - I am installing on a windows 7 vm running inside osx lion. I have tried installing as administrator and running under local account and installing as an administrator and running as an admin - both result in the same error "...vmware-hostshared foldersjustinmind4.4.1configuration could not be created. Please choose a writable location via the -configuration command line option"
Could you check if the folder vmware-hostshared foldersjustinmind4.4.1 exists please?
got it working, I just modified the Justinmind prototyper config file. and removed the @user.home.
have you tried to save a project that contains images, and then reloading that file? I end up with what appears to be broken paths to all images ("red X boxes"), everywhere an image had been.
it does not
It looks like the path is wrong some way (just an off topic, Justinmind is not intended to be used on virtualized computers). The good one should be vmware-hostshared foldersjustinmind4.4.1 . Open the file named JustinmindPrototyper.ini which is next to the .exe in the Justinmind's installation folder. Change the path @user.home... by the correct path and check it again please.
I've just had the same issue. Does anyone know how to fix it?
Which version of Prototyper are you using?
I'm having this problem too on a mac 10.6.8 (installing 10.8 now to see if it's working with that).
The text:
The configuration area at '/Users/myusername/Justinmind/5.1.10/configuration' could not be created. Please choose a writable location using the '-configuration' command line option.
I have no clue how to do that. Do you do it through terminal, or...?
You have to cmd+click on Prototyper Pro application and select 'Show package contents' Then open this folder: /Contents/MacOS/ and there edit the Prototyper Pro.ini file. Remove everything that is below @configuration (that line included) and run Prototyper again.
Ok. This is what I get when I open Prototyper Pro.ini:
Last login: Wed Mar 13 13:28:39 on console
Myuser-MacBook-Pro:~ Myuser$ /Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini ; exit;
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 1: -configuration: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 2: @user.home/Justinmind/5.1.0/configuration: No such file or directory
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 3: -data: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 4: @user.home/Justinmind/5.1.0: No such file or directory
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 5: -vmargs: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 6: -Xms256m: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 7: -Xmx512m: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 8: -Xss512k: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 9: -XX:MaxPermSize=256m: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 10: -Dorg.eclipse.swt.internal.carbon.smallFonts: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 11: -Dfile.encoding=UTF-8: command not found
/Applications/Prototyper Pro.app/Contents/MacOS/Prototyper Pro.ini: line 12: -Dsun.jnu.encoding=UTF-8: command not found
logout
[Prosess utført]
Is this how it should be?
Sorry, I should have been more clear. You have to open Prototyper Pro.ini with a text editor.
Ok, got it. Thanks!
I'm confused: How can this be labeled "Solved?" I don't see a solution other than going in by hand and messing around with some Windows config files or something. I've worked in the software industry for many years and this is unacceptable -- installation should be straightforward and trouble-free. This is not a good out-of-the-box user experience.
I saw the comment that Justinmind was not meant to be installed on a vm. This makes no sense to me. The installer should see Windows 7 as an actual OS and install accordingly.
I was evaluating this as an alternative to Axure. Guess I stick with Axure for now.
I got the same problem. I'm using OS X 10.6.8.
In text editor it says:
-configuration
@user.home/Justinmind/5.6.0/configuration
-data
-vmargs
-Xms256m
-Xmx512m
-Xss2m
-Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl
-Djavax.accessibility.assistive_technologies=
Which lines do I have to clear?
And then I can't save this file again.
Any other solutions?
Hi Tina,
Create a new file with a text editor and paste the following code:
-vmargs
-Xms256m
-Xmx512m
-Xss2m
Then, save it as "PrototyperPro.ini".
Now, what you have to do is cmd+click on Prototyper Pro application and select 'Show package contents' Then open this folder: /Contents/MacOS/ and there replace the Prototyper Pro.ini file for the new one that you have created.
