Installation problem on Mac OS 10.8.5 French
geraldine satis shared this problem 5 years ago
Hi. I have an installation problem with Prototyper Pro. I installed it. I have an error message after the installation saying there is a problem and asking me to check the log. I have Mac OS 10.8.5 French. Can someone help me?
The log is long. Should I type it here?
!SESSION 2013-11-01 13:23:24.423 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_51
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=fr_FR
Framework arguments: -keyring /Users/geraldine/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Pro.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/Justinmind/5.5.0 -keyring /Users/geraldine/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Pro.app/Contents/Resources/Java
!ENTRY org.eclipse.osgi 4 0 2013-11-01 13:23:26.025
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
at javax.xml.parsers.SAXParserFactory.newInstance(SAXParserFactory.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.createService(EclipseAdaptorHook.java:152)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService(EclipseAdaptorHook.java:144)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:141)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:139)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.java:411)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:317)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getXMLParser(RegistryStrategyOSGI.java:304)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1062)
at org.eclipse.core.internal.registry.ExtensionRegistry.addContribution(ExtensionRegistry.java:1040)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.addBundle(EclipseBundleListener.java:184)
at org.eclipse.core.internal.registry.osgi.EclipseBundleListener.processBundles(EclipseBundleListener.java:90)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.onStart(RegistryStrategyOSGI.java:224)
at org.eclipse.core.internal.registry.ExtensionRegistry.(ExtensionRegistry.java:725)
at org.eclipse.core.runtime.RegistryFactory.createRegistry(RegistryFactory.java:58)
at org.eclipse.core.internal.registry.osgi.Activator.startRegistry(Activator.java:137)
at org.eclipse.core.internal.registry.osgi.Activator.start(Activator.java:56)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClass(MultiSourcePackage.java:31)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:614)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.core.internal.content.Activator.start(Activator.java:48)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:171)
at org.eclipse.core.internal.runtime.InternalPlatform.openOSGiTrackers(InternalPlatform.java:788)
at org.eclipse.core.internal.runtime.InternalPlatform.start(InternalPlatform.java:710)
at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:30)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2013-11-01 13:23:26.027
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.ServiceException: Exception in org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook$ParsingService.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:151)
Caused by: javax.xml.parsers.FactoryConfigurationError: Provider org.apache.xerces.jaxp.SAXParserFactoryImpl not found
... 94 more
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.027
!MESSAGE Could not parse XML contribution for "org.eclipse.core.runtime//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
org.xml.sax.SAXException: Could not acquire XML parsing service.
at org.eclipse.core.internal.registry.ExtensionsParser.parseManifest(ExtensionsParser.java:392)
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.029
!MESSAGE Could not parse XML contribution for "com.justinmind.evc//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.033
!MESSAGE Could not parse XML contribution for "org.eclipse.ant.core//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.034
!MESSAGE Could not parse XML contribution for "org.eclipse.core.contenttype//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.036
!MESSAGE Could not parse XML contribution for "org.eclipse.core.expressions//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
!ENTRY org.eclipse.equinox.registry 4 0 2013-11-01 13:23:26.037
!MESSAGE Could not parse XML contribution for "org.eclipse.core.filebuffers//plugin.xml". Any contributed extensions and extension points will be ignored.
!STACK 0
Comments (5)
please, take a look to this topic. At the end of it, you will see how to solve it.
Best regards,
Which topic? I cant' see any link.
Thanks,
Sorry for my miss!
Here's the link https://www.justinmind.com/community...
Go to the end of it and you will see what you have to do.
Thanks, I successfully opened the app.
