install ok, but launch failed with the message "failed to create virtual java machine"
jiboux P. shared this problem 3 years ago
I've even tried to reinstall with the latest version of java while having deactivated firewall/antivirus (and disconnected internet connexion for safety reasons)
My config :
java : version 8.25
W7
justinmind : 6.3.1
Thanks for help!
Please try uninstalling Justinmind and reinstalling; you can find Justinmind here: http://justinmind.com/download
If you get the same error please send the followin log files to jim.support at justinmind.com:
For PC users:
- The list of the contents of these folders: c:usersyouruserJustinmind(any folder you find inside)
- The file called 'logs.log' inside those folders
- The file .log located in c:usersyour userJustinmind(any folder you find inside).metadata
- The files ending in .log inside c:usersyour userJustinmind(any folder you find inside)configuration if any
Marc
