in Windows 7 x64, I can't select the interaction (on tap, slide...) when I click "Add event". it's blank
DD shared this problem 4 years ago
d5b5a597d7b1d644d290fb9815bf0ee2
If you are using Windows 7, 8 or 8.1, it's possible that your system fonts are setup to 125% or 150%. You have to change it to 100%. It's a problem that we will try to fix for the next update.
Best regards.
Thank you for reply, but my system font size setting is default (100%).
Can you send me a full screenshot, please?
