Import vector file from photoshop/illustrator
Hayley Dineen shared this question 4 years ago
How can i import a image/widget drawn in illustrator or photoshop into my prototype. Saved as Jpeg - which has worked for other images but is not working for these vector files.
help!
Hi Hayley,
The problem is that when you export them to .jpeg prototyper can't read them?
Would you mind attaching an image that prototyper is not being able to read?
Marc
HI Marc,
Its odd because i have been able to import other .jpegs into the prototype. here is an example of what I'm trying to import!
thanks
96bfbfbcbb241ce9e433d0566871fe20
Hi Hayley,
Can you try exporting the image in some other format?
Also, in the next software update it is planned that Justinmind will support vectorial images in ".svg" file format.
Marc
