I can't simulate my prototype with v4.6
Carlos shared this problem 6 years ago
If updated prototyper from 4.5 to 4.6 for PC and I cannot simulate it, forcing me to stick with version 4.5. If I press simulate, prototyper will get tied up processing forever, until 5 minutes later a message will appear with "Windows can't find the file "file:////psf/Home/Justinmind/4.6.0/work2/project_sueloesp/index.html". I use the PC version in a mac (with parallels desktop, it goes a little faster than the mac version), but I've encountered the same problems when simulating with the mac 4.6 version and with the PC version in a PC.
I've tried simulating with an empty prototype with just a drop-down select list, and though it does simulate, the drop down list does't drop down when clicked (with the PC version in a mac; it does drop down with the PC version in a PC and with the Mac version).
What can I do? Is there a mug?
Comments (5)
Does the option File -> Export to HTML work?
No. It gets hung for ages until finally a similar message appears: Windows cannot find "file:////psf/Home/Documents/Suelo.es/Web/Prototipo/sueloesp/indez.html". I didn't have any problems simulating with previous versions.
Then I think there should be a problem with Paralels. We don't support Paralels and we don't run any tests on it. So maybe you can try to download the mac version of Prototyper and see if it goes faster.
But as I mentioned, I encounter the same problems when trying to simulate with v4.6 either with the mac version or with the PC version in a PC. I already tried downloading the mac version. So it can't be Parallels. It seems to be a problem finding the index file (or the fact that my prototype is 42MB made with previous versions).
Now I see that the path ends with 'indez.html' instead of 'index.html'. Can we take a look at your prototype please (send it to jim.support at justinmind.com)?
