I can NOT select other events once I select "On Double-Click"!
Li shared this problem 5 years ago
When I select the event "On Double-Click" the icon (where I am supposed to see which event I have selected) is empty. This also entails that I cannot change to implement behavior for events. Can you please fix this?
Also the interaction I created for "On Double-Click" is not working, while it does work for the event "on Drag"
Comments (10)
May I ask what operative system and version of Prototyper are you using please?
Windows 7 Enterprise and Prototype Pro Edition version 5.1
Right now I am using the 30-day trail version
Are you using 'big fonts' in your Windows?
Define "big fonts" ? What is "big"?
If it's about bigger fonts for the icons on my desktop, I haven't changed it.
Right now the default is Medium (125%).
That's what I meant. Just to check, could you change it to 100% and try again please?
Great I can see the icons now :)
The only thing that still does not work is the double-click event.
If I implement the same interactions for "on Drag" it works but not for double-click
Could you try with a very simple on double click interaction? Something like 'on double click -> hide this rectangle'?
Sorry for the late reply. I tried it today and suddenly the double-click does seem to work so I think that problem is also fixed! Thanks :)
Good! Sometimes the javascript of a prototype could take a bit long to load. That might be the cause of the bug you found the first time.
