HTML download messed up (missing js and css files)
Praveen Seshadri shared this problem 7 years ago
JustinMind is very promising. I tried it and created a project, loaded on usernote and some of the image alignment is messed up. So I tried downloading the html to see if I could fix it up locally. But the downloaded html doesn't work. First, most of the javascript files seem to be either missing or squished together into jim.js (which is not referenced in the html). The style sheets also seem to be missing or squished together into jim.css. Is this a known problem? The HTML is really valuable as a way to show other people andget feedback, but can't show it in its current form. ...
Comments (6)
I think the problem is related with the menu items. You have some menu items with texts in them that are shown in the HTML but they are invisible in Prototyper. How did you make those menu items?
Hi Victor, I didn't do anything special and nothing at the HTML level. Everything was done with prototyper. The blue "arrow" images and other small icon images in my menus were just added via prototyper and they all displayed fine on prototyper. I moved my .vp up to usernote and then it has this problem. I think the images within the menu items are losing their position and being aligned in the middle of the corresponding menus.
Tried to debug by downloading the HTML from usernote, but as I mentioned, the HTML download is missing .js and .css files. My prototyper trial period has expired and this (being able to get user feedback via a HTML web visualization) is the key and missing part of my evaluation of the product.
We found there is a bug in the text alignment of the menu items when the menu is set as a vertical menu. You can replace those menu items by simple labels. You can send an email to jim.support at justinmind.com requesting for an extension on your evaluation license if you need.
Great. I will ask Jim for an extension and try it out. Thanks for your help. I really want to get to the stage where I can use UserNote to get feedback on designs.
Separately, do you guys have abug causing missing files in the html downloads?
It's fixed but you have to publish your prototype again and then download the HTML files
