How to specify Event - Move, transition speed.
robert gerson shared this question 5 years ago
Event > On Page Load > Move
How do I set the transition rate for the image that is moving on screen?
The default seems to be for the image to immediately move to specified position.
I want the image to move very slowly across the screen on page load.
Thank you.
Hi Robert,
You can do the following:
1. Insert your image.
2. Add the move event and configure it "by offset" x: 10 and y: 0, for example.
3. Add another event, in this case Pause. Configure it with 100 milliseconds, for example.
4. Copy both events and paste them as many times as pixels you want to move the image.
Here you have an example.
16bfae5fff9d89987d308b622b53f009
I hope it helps you.
That works. Thanks for the solution.
