How to show value or values from one data row
dorich shared this question 6 years ago
I want to pull one particular value in one row from a data master and display the value on a screen.
I tried the following using the cars example:
Added a datagrid to the screen.
Created an onPageLoad
Selected the data grid where I want the value to appear
Clicked on Calculated
Set up the following condition FILTER [DATAMASTER NAME, Attribute Name = Cobra]
Clicked OK and ran simulation but the result is the listing of the whole table.
Since the data grid is showing the list I assume I'm linking correctly the data grid so the problem must be in using the FILTER. However, I looked at this response (http://gsfn.us/t/2zw71) and it appears that I'm taking the right approach.
What do I need to do to make this work?
Can you send the prototype to jim.support at justinmind.com? We will try to do it for you
