How to populate input values to an object in variable
Marian shared this question 6 years ago
I have an issue with New and Modify screens. I would like to store data that are put by user to certain fields. Problem is that I need to allow user to go to pop-up window from New screen, make a selection and then a navigation links user back to Previous screen. Alas all the data inserted by user are erased. I would like to store values in variable, but I don't know how to set variable to act as an object of certain Data Master type and store values so I can set them again with onPageLoad event. (I know workaround - to create variable for each single attribute, but it is not a systematic and efficient resolution)
You can take a look at this video tutorial http://www.justinmind.com/prototyper/... it explains a similar case than yours.
