How to make an accordion menu linked to dataset?
Leeman shared this question 6 years ago
I have first level and second level menu item. I want first level to show on android device menu bar, then when I click the menu bar, the second level (sub) menu appears. Each sub menu bar has a radio button on the right.
A second part to this function is that I want the menu bar text, first and second, to be linked to a dataset.
I'm sorry but menu items can't be populated with data from a data master. Instead of use the menu component you can try to build your own menu component and populate a Label or a Richt Text widget. Here you have more information about how you can build your own menu.
