How to Filter on Data Grid and Apply the Results to Variables
Zane Winberg shared this question 5 years ago
I have a data grid called RepairItems. I am selecting the RepairItem_ID's using this statement: Select[RepairItems, RepairItem_ID]
It returns 6002,6003,6005 for this example. My user deleted rows 6001 and 6004 from the data grid during simulation and that is why it is returning 6002,6003 and 6005.
What I want to do now is take each of these remaining rows (RepairItem_ID's) and apply them to a new variable which contains the row's contents for each for further manipulation. For example:
Put the row contents from 6002 on varRow1
Put the row contents from 6003 on varRow2
Put the row contents from 6005 on varRow3
I am not sure how to write an expression to do set the value for each varRow.
Comments (4)
Take a look at this tutorial:http://www.justinmind.com/prototyper/...
In the tutorial only one row is stored in the variable, but a variable can hold also many rows.
Hi Victor,
Thanks for the response... revisiting this issue again today. Unfortunately, from your video suggested, I don't see how to simply use a string function to parse a variable that holds these values (6002,6003,6005) and put each into its own variable (example: varRow1, varRow2, and varRow3) for further use in my prototype.
I don't really have a row_1 type of scenario to use as an attribute for filtering out what is in the variable as a string value (6002,6003,6005). So I'm just looking for a way to parse the variables values, separated by commas for further use as described.
Do you have any suggestions for me? Maybe I missed something.
Thanks again...
Hi Zane,
Sorry I didn't understand you before. What you need to do is to use the 'substring' function to split the value in the variable in three. I made a prototype for you http://d2ld3he4yll0xl.cloudfront.net/...
Also, you can learn more about how to use the substring function in this two tutorials:
Thank you Victor! Works like a charm. I didn't understand the Index function well enough and this helped a bunch.
