How to concatenate a line break into a Select List widget
jackbellisgm shared this question 7 years ago
I'm able to populate a Select List on pageload with a data master via
"Select(datamaster,field)." But how can I append or prepend another manual row such as "Don't Use a Template". I can use Concat but there's no line break. Is there a list of special characters somehere? Like /cr or similar?
Thanks, jack
You have to concat "Don't Use a Template," notice the comma at the end. Commas are used to separate values (which was a bad decision cause then you can't have values with commas inside a select, but that's another story...)
