How to apply a static top bar that is always visible irrespective of Events applied
jameshamburger shared this question 5 years ago
Hello there,
i just created a slide-out menu using the 'Set Focus on' functionality.
However, I am having troubles as it does hides the visibility of the 'Top Bar' (iPhone Top Bar which displays the Carrier, WiFi Connection, Battery life etc.).
How do I set so the Top Bar is always fixed and visible irrespective of what 'Events' I apply to my screens?
Comments (6)
Inside the top bar propieties, you can select 'always on top' option. Here you have an image that shows it.
93ce09201051ec92cb5321df24cdf7d8
I hope it helps you
Hi Albert,
I know what you mean - but I mean 'static' as in it is ALWAYS visible e.g. when I am scrolling down or up. It is always visible on the screen.
i.e. other elements on the screen may move but the top bar does not have at all.
Just add a dynamic panel under the top bar propieties. This dynamic panel must be between the top bar propieties and the tap bar, if you have added it. Now, go to Vertical Scroll option of the dynamic panel propieties and select the option Automatically.
Here you have a picture that shows you.
6ca7c82f1d53653baadf877c6ed973ce
I hope it helps you.
Okay, I guess this makes sense.
But what if I use the 'Event' of Set Focus on?
i.e. the focus gets set on an element - but it makes the 'top bar' not visible.
How do i Make the top bar always visible...
The set focus event just scrolls the inner panel, not the entire page, unless the page is higher than the display.
Please, send your prototype to jim.support@justinmind.com to help you.
Best regards.
sure thanks
