How to add panels to a dynamic panel
Franklin van Reem shared this question 5 years ago
I use the Carousel widget, it has standard three panels inside 1 dynamic panel. When I add a panel (4) al goes fine, I change the image, no problem. Then when I simulate, I only see the first three panels. Thanks
You need to configure also the arrows on the other panels to make you go to the new one. I think this tutorial might help you understand how the carousel works: http://www.justinmind.com/prototyper/...
