How do you set an onpageload event to cause a change in style of a specific row of a datagrid?
Christopher Davies shared this question 5 years ago
If you have a datagrid and you want the style (background colour, font colour) of a specific row to change on page load, subject to some criteria, how would you do this? The key is addressing the specific row I guess. I have made a simple example here where the entries in the grid under name are '1', '2', '3' and the entries under status are 'a', 'b', 'c'. In this example I want the first row to turn red as it has the status 'a' in it. Is this possible?
4ad1461b0bbbc42bb1587a5753588da4
Comments (5)
Here is how you do it. 1b4b7707731f8fccc0a18464886218a5
great! Thanks John!
I knew there had to be a simple answer
actually, that second picture is no use - I can't see which things are selected and the last 2 boxes look identical. Can you take screen grabs where everything is labelled please?
Assuming you already have a data master with Name and Status data fields already filled (just like what you have above).
1. right click on the data grid -> edit content
2. select the second row of the data grid -> Add event -> on Page Load
For the condition, look at 'a.png.' You have to create the expression in that image.
- drag and drop 'Select' function under Collections tab
- drag and drop 'Row_1' to the first field under Screens tab
- drag and drop 'Status' field under Data Masters tab
- drag and drop 'has' function under text tab
- double click the last field and enter letter 'a'
click OK
3. To change the background color of that specific row, click change style -> select the second row of the data grid, 'Row_1' -> check background -> change background color to red
4. To change the font color of that row. Look at 'b.png'
- on the same on Page Load event, click the drop down menu next to 'do' -> click Add action -> Change Style -> select [test.Name] on the data grid -> click Text checkbox -> then change the font -> click OK
- do the same for [test.Status]
You can learn how to build complex expressions in our help and tutorials sections:
http://www.justinmind.com/help/index....
d5e966bb85dc3ded07844f3797372078
ah ok thanks! got it working now
