How do I set an active layer when an input is UNchecked?
Dann Gardner shared this question 4 years ago
A page in my prototype loads with a checkbox input unchecked and showing panel_1 of a dynamic panel.
I'm using an onChange event so that when that input is checked, panel_2 is set to active.
I can't figure out how to set panel_1 to active when that same input is unchecked.
Suggestions? Thanks!
Hi Dann,
in the conditional expression, just add a "Not" before the input.
6403bdeb9e5d976398ffb30c0bf9db95
Best regards
I figured I was missing something obvious... I kept looking for a way to change "is Checked" to "is Unchecked".
Thanks for the help!
