How can input text from one panel display in a select list of another panel?
Charles shared this question 6 years ago
After a user provides input into a input text field and clicks on a button all within one panel, I then need to have the input text appear in a select list (i.e., drop-down) of another panel.
I have tried using the set value event to set the value of a variable, then transfering the value of the variable into a Data Master field. Then on the other panel I pointed the select-list field to the Data Master field; however, the input from the original input field does not appear. Any thoughts?
You don't need any variable or data master to do that. Check a similar case in this video tutorial http://www.justinmind.com/prototyper/... contains a case called Inline Edit that does something similar like you want to do
