How can I re-order the comments manually to show the order I want as the publisher?
Brian Utz shared this question 5 years ago
Is there a way to restructure the order in which comments show in the simulation after they've been created? I created a general comment first and after others have been added it shows at the very bottom of the All Comments list. I'd like to be able to move it back to the top so you see it first.
Hi Brian,
If you want to re-order the comments in Prototyper, go to the Comments tab. There, you have to click on "created" tab. It will order by date. Another option is to click on "ID" tab.
If you create a document report, it order by date of creation.
I hope it helps you
Thanks Albert,
That's not exactly what I want. Let's look at it as a business requirement and screenshot tracking prototype. If I've entered all the BRs sequentially it works fine. However, if there's five BRs and I want to add BR 4.1 it will show at the top or bottom of the list. I'd like to be able to drag and drop it in the user note simulator to show that comment between the comments holding BR 4 and BR 5. let me know if that still isn't clear. I know I could just reply in that instance to the comment holding BR 4 but I'm trying to paint an image with a broad brush.
Hi Brian,
Now it's more clear. It's not possible to do what you want but you have found the workaround. Reply in the instance to comment.
But it's a good idea for a future update of our software.
Thanks for the suggestion.
