how can I add new items to a group?
vdekker.nl shared this idea 7 years ago
Completed
Is it possible to add new items to a group, because when I try to drag them into a group it will placed under the group.
Comments (8)
Just select the elements and the group and 'group them all'
Yes but then... their is a group in a group and that is messy. Plus that the first group have an action and after creating the new group the action is lost.
I want to prevent that.
Maybe you can add this function to the feature list?
Mmmm we will think about it.
Keep us informed about your decision :)
It's very useful action. Does it apear in 5.1 Prototyper version?
Sorry I forgot this thread :S You can add more widgets to a group using copy and paste on the group. So if you select an element that is out of the group, press copy, and then select the group and press paste, the element will be inside the group now. It works the same if you use cut instead of copy.
Is this the same if I use a subgroup (group that is in other group)? I do not observe similar behaviour.
It doesn't seem to work in subgroups. Thanks for telling!
