Horizontally toggling radio buttons
Becca Graveling shared this question 5 years ago
Is there a radio button for forms widget that toggles horizontally, rather than vertically? The 'Radio Button' seems to only work independently, so the 'Radio List' is a step in the right direction, but I can't find a way to edit so the buttons are side by side. If I could, this would solve the problem. Any tips please?
Comments (7)
Select the radio list, go to the properties and change the orientation to Horizontal.
That's it.
Okay, thanks a lot. This is what I was expecting, but where are Properties?
Ok, thanks. But where are Properties?
You can find it on the right
b31978f7d02a4f0c95cd9d6967b108ec
Great - thanks so much. I can now arrange my radio buttons correctly, but I need to remove the value for each button - effectively having no prompt, because they are organised in a table format with the prompt at the top of each column. Is it possible to do with this widget, or if not, is there another widget that will still allow toggling, whilst not requiring any prompts? (Currently, if I remove the prompts (values) the radio buttons disappear as well.) Thanks.
You can also use combination of radio buttons and labels. But you have to group the radio buttons by selecting all of them then hitting 'Ctrl+'G'.
John
Thanks for your response and sorry for the delay. I've removed the labels from the buttons purely by editing the values and removing the prompts, (which somehow it allowed me to do this time). However, now the buttons are correctly in situ and I've defaulted them to have the left hand button selected, every time I simulate the prototype they change to having the right button selected!
Any ideas how I can change this please?
