Hiding grouped objects does not work in HTML prototype
sebastian.ludolph shared this problem 7 years ago
Hi, when I hide a group of objects, often some of the objects in the group or even the whole group are still visible in the HTML prototype (both in the export and in Usernote).
A bug fix would be appreciated!
Comments (4)
You have to be sure you are hidden the group, not a component inside the group. If the bug is there anyway please send your prototype to jim.development@justinmind.com so we can take a better look at it or just send us a simple prototype with that bug.
Thanks, great response time! I did hide the whole group. However, I now figured out the reason: Say I have three objects. Then I group objects 1 and 2 together. Afterwards I group the first group with object 3. Then I hide the big group. This leads to the big group being invisible in the normal preview (as it should be in my opinon) and objects 1 and 2 still being visible in the HTML. I will send you a simple example file as a reference.
Is there any way to fix this? I quite often use subgroups in my prototype.
Well, it should work the same way as it does inside Prototyper. Let us check what could be going wrong.
Thanks for the prototype. Our engineers will check it out to find what could be the reason for not working in html. As a workaround you'll have to use simple groups without subgroups.
