Hide/Show event does not work in Simulation.
Ken Li shared this question 6 years ago
I follow exactly the tutorial.
I create an image, then hidden it with button in Properties, then add "mouse over" with "show".
When I run simulation and export to HTML, the image is hidden and simply would not show up when mouse pointing exactly there.
Please help
If you mark a widget as 'hidden' that means it won't be there until you show it. So the 'on mouse over' won't work because there is no image at that moment there. Instead of showing/hiding, maybe for your case it's better to play with the transparency level of your image. Remove your current event. Then select the image, go to Properties and set transparency 100%. Then create an on mouse over event -> change style -> transparency 0%
