Glitch or bug???? Event item missing!
harlan shared this problem 5 years ago
For some reason the event action "ON CLICK" as completely disappeared from the menu? I've restarted and reinstalled and still no "ON CLICK" option.
Are you using Windows? It is probably because you are using bigger fonts. If you change your Windows font size to its default (100%), you will see the 'On Click' option.
Here's how to do it: http://windows.microsoft.com/en-us/wi...
Found the problem : not compatible with windows7 / 8 Chinese language. After the windows change the language to English fixes the problem . Please fix this BUG.
Thank you for your findings. I will report this bug to the development team so that it can be considered in a future release.
Best
