Function: GetPosition or onDragStop for iPad
Thomas Binder shared this problem 6 years ago
Is there any possibility to get the position of an object or is there any function like onDragStop which is also working for iPad?
My Problem:
I'm moving an object on the iPad by onDrag. If i'm stop dragging the object i need something to check if it's current position is the target position the object needs to be move to.
Yes, there is an event type called 'on drag stop' to handle that. You can take a look at the tutorial about how to prototype drag and drop. The examples there are also quite useful.
i've already tried this event, but when i'm going to define a destination widget with "when drop on", this is only working on the PC/Mac and not on the iPad, which is the target platform for my prototyp.
You're right. It has been fixed in the version we launch tomorrow.
