Font fallback happen on Roboto condensed Regular #GoogleFonts
Gaurav mishra shared this problem 2 years ago
Known
I have used the roboto sans condensed - light after installing into my system. Later i installed the same by adding it from Google fonts. After this operation i noticed that roboto condensed, light variation looks garbled - each character separated by lots of whitespace.
Then i close the file and inspect the fonts, it looks better and not garbled any more.
One concern, i have found is the font i have used in text, render via Roboto condensed - Regular variation
But i had declare the roboto condensed lighter variation, if the engineers can take of the case.
Can really save lots of work hours in correcting the same
Hi Gaurav,
The problem is probably that not all roboto font types have been downloaded and, as you have them installed on your computer, instead of using our regular Roboto font, it is using the system one and leads to errors.
What you can do is go to the font folder which is located inside Justinmind installation folder and examine if all roboto variants are there and, if not, delete all roboto fonts and download them again from the font dialog on Justinmind, and then all should appear.
