Flash/Chart Widgets
Ash shared this problem 6 years ago
The char/flash items are not working. When I drag chart widgets, it does not display the graph. It worked in the past but not anymore. I'm on ver 4.6.1. Thanks
The charts library was made some time ago and the flash items we used might be obsolete. I recommend you to use Google Charts api instead in combination with the HTML widget in Prototyper.
https://developers.google.com/chart/
Thanks. I liked the workaround however the chart doesn't adopt to the widget size or coordinates. For example, I am not able to correctly display the chart on an iphone simulator. In order to properly display the chart, the widget size has to be same the chart size.
Any solutions?
