Filtered Data Grid ignores Interactions
Drew shared this question 4 years ago
BACKGROUND: I am building out an email system with a data master of emails that includes attributes such as To, From, EmailAddress, Date, Body, etc. I also have several attributes primarily for filtering data grids (read = true/false, starred = true/fales, status = inbox/draft/sent/trash/deleted). I then use the same *read* and *starred* attributes in onPageLoad events to change styling and show/hide the star. All of this works great.
THE PROBLEM: when I "Set Value" of a Data Grid using a Filter. As soon as I do that, it appears to ignore the styling and show/hide star interactions.
FUTILE ATTEMPTS: I have tried with the filtering interactions both before and after the styling interactions. I have tried the filter and the styling on different objects in the hierarchy (e.g. grid, row, cell, image). I have tried different event listeners (e.g. onClick, onPageLoad, etc.). I have even tried setting a variable, reloading the page, and filtering based on the variable.
I know that my data grid remains correct, because if I add checkboxes for the booleans they display as expected; and if I remove the filter my styling magically reappears. Any help is appreciated.
Comments (5)
UPDATE: when the filter is applied before the styling interactions, those interactions actually take effect - however - instead of applying the styling based on each row's attributes, it applies the styling to all rows based on the attributes from the first row.
Hi Drew,
This tutorial explains the star part: http://www.justinmind.com/support/use...
Please send the .vp file to jim dot support at justinmind dot com so I can figure out the way to make your prototype work.
Marc
Ok. I emailed the file. To see my issue, go to the Email Inbox screen and click the menu on the top right. Then click "starred." Thanks!
I continue to run into this same issue. This project is a trial and I am evaluating Justinmind Prototyper, Axure, and Invision to see which one our company should purchase. Any help appreciated.
FIXED IT: For some reason, if you place the filter on the row (which I did), you'll get the unexpected results I mention above. Simply moving the filter to the Screen as an onPageLoad event fixed everything for me. Here's how it works:
Click on the Inbox Screen in the Screens Menu and add an onPageLoad event When variable Filter=starred {
Set Value [ Filter[ MessageDataMaster( starred=true )
NOTE: clicking outside the canvas will NOT work--that will just give you a "no items selected" message. That had lead me to believe you couldn't add events to a page.
Add an onPageLoad event to Row_1 of your Data Grid:
When Select[ Row_1, Read ] = false {
Change Style of Row_1, background = white
Add an OnTap event to the button (or menu item, or whatever you want to apply the filter) with the action - Set Value of variable Filter="starred"
Add another OnTap action to that same button: Link to Inbox (this will simply reload the same page, at which time the onPageLoad event from step 1 will take place!)
Although I'm happy to have discovered the fix, I am sad to say I received no support from Justinmind.
