Expression builder problems
Matt shared this problem 4 years ago
The expression builder seems incredibly buggy in building simple expressions. The parenthesis get put in the wrong place - is there anyway we can just type these in until it gets fixed?
I.e. all i want is:
(A = X) AND (B = Y))
But i keep getting:
((((A = X) AND B) = Y))
Matt, here is a quick bit of help. I had the same problem and was frustrated. The solution is in your mouse technique.:-)
Place the expression values slowly and slide them up into position from the bottom of the expression exactly where you want them. It may take some trial and error, but you will be successful, then it won't be hard anymore.
