Event window is Blank!!
kui shared this problem 5 years ago
As image below...
dbd0e6afed91d402eaea64ca53f361e4
Comments (5)
Hi Kui,
Close Justinmind Prototyper and change your system language to English, for example, and open it again.
It should work
Thanks! It works!
I'm having this problem as well, and my system language is set to English http://i.imgur.com/kmoAXQa.png
Hi Jamie,
which is the size of your fonts? is it 125% or higher? If yes, change it to 100%
That did it, thanks.
