Error with Invalid Configuration Location
mike.mullikin@wellsfargo.com shared this problem 6 years ago
Trying to run trial version for first time and receive error: "The configuration area at DTCHYB...C_WBGWDG_Usersmullik999Justinmind4.6.0configuration could not be created...." I tried using the -configuration command line option and the app just hangs when trying to start.
Comments (7)
Hi Mike,
1. Do you have write permissions on that path?
2. Are there any spaces in the path?
3. Are you using Mac or Windows?
If you dare, remove the first 4 lines in the file JustinmindPrototyper.ini located in the installation directory of Justinmind Prototyper.
Removed the first four lines of that ini file and it worked. Thank you.
It works now, I installed with admin rights, i opened with admin rights, of course my account has fully admin rights, but why does this happen "Error with Invalid Configuration"
How do you remove lines of a .ini file?
press start button -->Type Notepad --> RightClick --> Run as Administrator --> Yes --> File --> Open --> Open the *.ini file--> Delete the four lines--> Save --> Exit
What about a fix for mac? Running ML on an Air. 0e09fcf58c85a1950b2737b37940a52a
I also get the same error with the pro trial version. Really need and want to get to work with this awesome tool.
Select the app in Finder, ctrl+click in it and select Show Package Contents. Then select ContentsMacOSJustinmindPrototyper.ini. Open that file and remove the lines:
-configuration
[a path]
Then save it and try again.
