Enable the copy and paste of ALL interactions for an object.
dsthompson shared this idea 7 years ago
Completed
Sometimes Interactions can be complex AND apply to more than one page.
But you can only copy one interaction at a time.
Make it so that you can copy all the interactions for an object in a single copy command and them paste them all into another object.
Comments (9)
You can use the broom events tool in the toolbar to copy all the interactions from one component to another. But I agree there should be also another way to do that.
I think this would save me a lot of time. Can Weyand them As Widgets and tgen use them frm the widget library
Great suggestion!
Could the documentation be updated to specify this? The Copy Styles entry doesn't communicate this at all.
I may be completely missing this but can you explain how the broom tool works to copy multiple interactions between components. I cant get this to work at all. Thanks.
You can follow these steps:
1.Select the component from where the interactions will be copied.
2.Click on the broom tool b5601107811c1beba1a336e199128916 to copy the interactions defined on the selected component.
3. Click on the component where you want to paste the interactions.
Thank you for clarifying this. I think I was expecting to see a "Paste" option. Works great now.
Included in version 5.5
Very handy feature, which I just discovered in 6.0. Glad it's there!
