Editing Table Text is Broken
cgarts1200 shared this problem 6 years ago
Cant edit a tables fields any longer. This happened out of no where. I closed Justinmind and even restarted the computer. Please tell me there is a quick fix for this because I have spent months on this project and being able to edit tables is a MUST.
Nevermind I figured out the issue. If you have a comment on a table you cant edit it.
I had this issue too and it took a while to figure out. Seems to me that you should be able to keep a comment there and edit the fields. If the comment no longer pertains, then you can delete it at a later date.
Solved in 4.6.1
