Dynamic pagination with dynamic panel ?
Nuttakron Dheeravoravong shared this idea 6 years ago
Under Consideration
This time i'm working on prototype via JustInMind and my boss need me to create prototype looks like slide picture, so I'm using dynamic panel for make slide picture and add transition after change picture too.
At first there were 5 - 10 pictures is no problem, but when my boss gives 20 - 50 pictures to add in prototype, I must create 50 panel and create expression interaction 50 cases !!.
( if page = 1, active panel page 1; if page = 2, active panel page 2 ;..... if page = 50 , active panel page 50 )
It's making high load memory when i'm clicking on button with 50 interactions or save prototype project
In my opinion It should have some dynamic panel with pagination function or user can write interaction by coding. It'll be easier to create dynamic prototype
p.s. I'm using "select list" widgets
Thankyou
Comments (4)
You can use dynamic panels instead. Take a look at this tutorial http://www.justinmind.com/prototyper/...
Hello Victor
Thank you for your answer, I'm really appreciate :)
I'm already use dynamic panel, but it's making a high load memory.
" if I tried to create 50 dynamic panels and add interaction 50 cases in one select list widget. " ( https://docs.google.com/open?id=0B5fd...
(e.g.
when select list = "1", set active panel page_2,
when select list = "2", set active panel page_3,
when select list = "3", set active panel page_4, .........
when select list = "49", set active panel page_50,
I think, it should have some dynamic panel with pagination function or user can write interaction by coding (text code may less load memory). It'll be easier to create dynamic prototype :)
Thank you
here this is sample widget create by me
Thanks for sharing the widget!
