Dropdown control default setting
ali.peppard shared this question 7 years ago
Can you set a default value in the standard dropdown (select list) widget? I need the most common value to appear without the user having to use the control.
Whatever value displays in the "Value" field of the Selection Components properties panel (bottom right) displays the user by default.
Thanks for your help Michael!
