Drag&drop problem when reordering objects in a panel with horizontal alignment
alex shared this problem 7 years ago
I have a drag&drop problem when trying to reorder objects in a panel with horizontal alignment. It works fine in the vertical example.
The problem only occurs in the HTML export. You can check it in this simple example:
http://files.vision-robotics.com/mcp/...
It is not possible to set a colored square in the middle position. Always I try to drag a square, it is positioned in the last position.
You can find here the JIM project,
Is there a way to do so?
Thank you very much for your help!
Alex.
You found a bug! We are working on it.
