Display numeric variable from equation without it turning into a bool true/false value
Cooper Newby shared this question 3 years ago
I am trying to increase a variable every time a button is pushed and output the variable value to the display but every time i try in the calculations page, the variable outputs as true or false instead of a number
Hi Cooper,
Please take a look at this tutorial: http://justinmind.com/usernote/tests/...
I believe you will find it very useful.
Marc
Thanks! Do you know if I can store that value in a variable so i can use it across pages?
Hi Cooper,
Using the setValue event and selecting a variable that you have created in the Variables panel as a target of the event you should be able to do what you are asking.
Marc
