Difference in calculations between simulation and exported html
Kim shared this problem 6 years ago
I made some calculations in a prototype. When i do i simulation everything works fine. However, when i export the prototype, the calculations are NOT right. Does anyone know how these differences can be explained? For a example see www.zorginkopen.nl/evean
Thanks in advance for your reply, kind regards, Kim Brand
Comments (9)
Could you detail what are the differences please?
apparently the outcome of the formula differrs. i'm not sure what part of the formula in the expression is excluded (because it's a long formula)
Could you send an example to jim.support at justinmind.com so we can take a closer look at it please?
Kim, I share your grief!
I've been struggling with calculations for days.
In simulation it's fine, but in Usernote it is not.
When you calculate in a Data Grid it is easy and it works, but it calculates per each row only.
I wish JIM would come up with a solution that was easy to use, like data grids or Excel.
Hi Markku,
I'm sorry but I don't get it. Could you detail a bit your case please?
Yes, please go and see page "Palkanlaskenta_monta" on the link I sent you. Try to open the second green group and use the first group in it to calculate. Download that prototype to see how differently it works in JIM. Also try the trashcan and see how it suddenly starts to calculate fields that were not calculating before.
JIM is fantastic piece of software but we need to get these calculations easier to use.
Ok, working on it.
I'm thrilled to see what comes up :)
Victor, i did send the prototype about a week ago. Any status update on that request? I'd like to get the calculations working.. Thanks in advance for your reply.
