DataGrid "the selected item is not valid"
Raul Gros Claver shared this problem 5 years ago
I have a problem, I need to filter a datagrid. When add a interaction "select value" to a datagrid, show the message "the selected item is not valid", but if add a list i dont have this problem.
Check these tutorials to learn how to filter data grids:
I check these tutorials and "select the entire table" but show this message.
You need to use a 'set value' action, not a 'select value' one.
