data master created pages not aligning
120000km shared this question 8 years ago
I created 1 Data Master item, it generated 5 pages (new,delete,modify,view) I generated the HTML but when I view it in IE or Firefox it does not line up correctly. How do i get this corrected? As you can see in my image example. the table should be under the title "Careers" and "Direct Applications to" items.e76ecdef3ea247747943fdb4a5237edb
Comments (4)
Did you move the generated content before exporting to html so that the content will be under the title? I mean, is the data grid overlapping the title also in the screen inside the Prototyper or just when you export to html?
I positioned everything as it should be in Prototyper, then generated HTML.
- Simulate looks as it should
- .vp upload to Usernote looks very bad
- upload to a regular site location looks even worse
http://31moons.net/test/#viewlist%20C...
only the viewlist page that was auto-created does not present correctly. How can I fix this asap?
We found the error. The thing is the generated screen has a layer that is called layer 1 and we don't support spaces in layer names. Just rename that layer (you can find it in the Outline view) to any name without a space and it will work.
