Data Master Action: Executes New - The new row is not shown?
kakuda shared this question 7 years ago
I have created the following page:
8428435587fc13fb974171f29a43250d
The table sits in a dynamic panel.
Edit existing:
1. A click on a row, opens the dialog below filled and you can edit the item.
2. Click on Button "Speichern", wich has a Data Master modify Action und a action to show the dynamic table panel.
3. The result ist: you see the changed values in the table.
Create a new:
1. A click on "Sendung hinzufügen" opens the same dialog empty, ready for input.
2. Click on Button "Speichern", wich has a Data Master New Action und a action to show the dynamic table panel.
3. The result ist: you see don't see the new row in the table.
It only shows up, when I leave the current page and then come back.
Why is the behavior between Modification and New different. Ist there any tip, how I can show the new row without having to reload the whole page?
To show the new row you have to update the values in the data grid. Check this ticket http://www.justinmind.com/community...
Thanks for the tip. That works!
