Data Master Action - New - Images on expression
Alessio shared this problem 4 years ago
I want to create a new row in a data master, passing 2 text attributes and an image, when i click on a row of an another datamaster. The problem is that when i create the event Data Master Action on click, and put the image component in the expression, this become highlighted in red and the alert say: "The highlighted expression is. Replace it for another one having a text result."
Is this a bug, or i can solve this with some work around?
Thank you 95b388b73ac2aa0782e0f730782dc637
Hello Alessio,
The reason you are receiving this error is because the data master field (Foto) is expecting a text value. Since the value of a image widget doesn't return text, it can't complete this action. In order to add a row with a picture, you will need to specify the file path as the text for the data master field holding the image. You may find the following tutorial helpful in understanding this:
http://www.justinmind.com/support/sho...
Sincerely,
Luisa
Thanks Luisa,
i solved putting the image widget in a variable, and then passing the variable in the expression of the Data Master Action.
I love you all :D :D
