Customized prototype generation for selected screens
Amr Medhat shared this question 6 years ago
How to select specific pages to generate and publish from the prototype (not all screens) ?
Comments (6)
I'm afraid this can't be done. I don't know if an option to allow this will be very helpful. Please could you explain your case and why you don't want all the screens to be generated? It will help us to known how critical is this lack of functionality. Thanks.
Thanks for you reply..
I used to use this feature when I was on axure for cases like the following scenario:
The client sees the prototype and asks for changes in some screens, so I duplicate the screens required to be changed and make all modifications and generate the prototype again with the updated screens only (while keeping old ones invisible in the tree) so that if he decides the old screens are better I can revert back to them directly.
In this scenario, did you changed manually all the navigations on the prototype referencing the old screens to make them reference the new ones?
Or did you keep the navigations to the old screens and explore the screens of the prototype using the contents tree on the left panel of a generated prototype with comments?
If needed, I change navigations to reference new ones , or just leave linking pages until agreeing with client on each screen layout (i.e. accessing pages from tree only)
Ok. I write down your suggestion so we could take it into account for future releases. Thank you very much for your feedback!
