Copy/paste from Illustrator CC 2017/2018
Lucas Krull shared this problem 1 year ago
Known
Copy and paste from Illustrator CC 2018 results in an empty bitmap image. Right Click > Image > Open with default application opens Photoshop...
Copy and paste a red rectangle from Illustrator CC 2017 also results in a bitmap, with a small part of the rectangle showing... See attached images.
Very strange.
Comments (5)
Dear Lucas,
Unfortunately, we haven't been able to reproduce your issue with Illustrator 2017 and 2018. Which OS and version are you using?
I have the same problem. I have updated 2018 InDesign and Illustrator. The copy and paste will not work between the two programs, nor is it working right in Illustrator itself, even within the same file. At this point I have to create a new layer to copy and paste within Illustrator. I have seen the red rectangle bitmap etc. but not every time.
I use Windows 7 and this only started with the update to 2018
Dear Charles,
We're trying to reproduce your issue. I'll get back to you ASAP.
Thanks Sonia!
Dear Charles,
We've been trying to reproduce your issue (in a Windows7 device with the latest update of Illustrator ) without success. We have been able to copy / paste without any problems. Which Justinmind version are you using?
*With Indesign there is no possibility to copy/paste.
