Copying Images from one panel to another
Craig Somberg shared this question 5 years ago
I have 13 images saved in 13 panels. I want to place an event for an onclick on the image to zoom it to 300% of actual size. Can the image be copied into another control dynamically?
You can right click on the panel where the image is -> click Duplicate panel
Thanks - but what I need is:
The user clicks on the image. I have another panel setup with a larger image placeholder. I want to copy or show the zoomed image on that panel.
You can set an image in panel 1 and then a zoomed version of that image in panel 2. Add 'On Click' event to the image in panel 1 -> select 'Set Active Panel' -> then click panel 2
