Copy once and Paste indefinetely an Event
Pierre shared this question 5 years ago
I am trying to move a dynamic panel, in an animated way.
I want to copy and paste [ pause 50 ms + move x by offset 5px constrained ], let's say, 50 times.
I don't want to have to click 100 times on "Add Event", to repeat the same steps, it's stupid and exhausting.
Why can I not click the Paste button and see the same copied event adding and queuing up as many times as I like?
What event are you using? 'On Click'?
If you are using 'On Click' then one copy of '[ pause 50 ms + move x by offset 5px constrained ]' would be enough.
On the other hand, if you are using a different event, here's what you can do.
On the event tab, click the drop down menu next to the event, then select 'Copy event'. Then just click the paste button. Please see screen shots.
Copy event
0a3f02c4ab23401ae42f7a236e667777
Paste event
Thank you so much! I was not that obvious but it works.
Though it would be really good, above all, to be able to do Ctrl-V to paste, and also, to be able to select a given set of events, three in a row for instance, and copy them.
