copy and paste a few elements offset position
Agnes shared this problem 7 years ago
Using Ver 4.2.0: on Win 7...Copy and paste a few layout elements off set the positions of some elements. Say I created element 1, 2, 3. If I do a copy of these elements and then do a paste using the regular keyboard commands, element 2 may not keep its relative position to 1 and 3.
I'm so sorry but I don't understand what you mean by 'layout elements off set the positions of some elements'. Could you explain it a bit further please?
Say I have 4 text fields, each vertically spaced at 10 pixels apart. If I select them all, and do a "copy", and then a "paste". All of them re-appears OK but usually the 3rd text field reappears but is pasted on the screen by an off-set of 4 pixels. Hope this helps.
I'm sorry but I can't reproduce the case. And I tried hard, I promise. It happens all the times when you copy and paste? Could you describe step by step how you get that error as if I were a dummy please?
