Converting prototype to C# code
amit agarwal shared this question 5 years ago
Hi Team,
I am new to JustinMind and am working in dot net environment. I wanted to know that if there is a way we can convert the prototype to the asp.net C# code. Any help in this regard will be really helpful.
Amit Agarwal
Comments (6)
Sure, take a look at our API section http://www.justinmind.com/plugin-mark...
Thanks Victor,I will check and let u know if that works for me..
@Victor, it appears that the conversion is allowed from prototype to java code.. I was looking for something which will convert it to dot net code..
Yes, but you can find a way to convert java to c#. You can create an API to communicate from JAVA to your C# code.
Thanks for the quick response..
